11-04-2025 10:10 AM
My computer does not recognize the device, there are no drivers for this???? Did i get ripped off by Cannon? How do I make it work? Otherwise it is a Cannon brick.
11-04-2025 11:44 AM
Thanks for joining the conversation, dabige101!
This community is designed for your fellow Canon owners to help each other out with any problems they may encounter. If this is a time-sensitive matter and you're based in the United States, you can call our imageFORMULA support team at 1-800-OK-CANON (1-800-652-2666). They're open Monday through Friday.
Thanks and have a great day!
11-04-2025 02:37 PM
Danny, Is there no other way to get this answered other than having to be put through your call center? I tried today and could not get a human in a reasonable time.
11-07-2025 01:22 PM
Please try downloading/installing the scanner driver from the link below:
https://soft.canon-elec.co.jp/ims/r40/en/
If the issue persists, we will have to recommend that you call our Enterprise & Desktop Solutions Divisions at 1-800-423-2366, Monday - Friday, 8:00 AM - 6:00 PM EST (excluding holidays).
11-24-2025 05:00 PM
Hi, I had the same problem.
I called the support line at 800-423-2366 and got it to work. I had too many apps opened so there wasn't enough memory for the driver to install. Try force quitting everything then install the app and the driver. If that doesn't work I called the above 800 number and only waited about 5 minutes to get support.
