Trouble connecting PIXMA G3520 to new network and router
GrahamP
PIXMA G3520  - I can't get it to connect to  a new Router on a new Network Error 3441
I have sonnet HOURS going round in circles
IO have tried using Smartphone Apple 16 max and iMac running  both running (Tahoe) IOS  26.5
Can anyone tell me how to solve this problem or how top get clear instructions and help please
1 REPLY 1
DerrickL
First it requires your router to send out a 2.4ghz signal, the printer cannot use 5ghz. Make sure you have a 2.4 ghz signal before taking these steps.
Steps to Connect PIXMA G3520 to Wi-Fi Using the Printer Panel
Preparation
  • Ensure the printer is turned on.
  • Confirm that the printer is within range of your Wi-Fi network.
Connection Process
  1. Access Home Screen
    • Navigate to the printer's home screen.
  2. Select Wi-Fi Icon
    • Tap on the Wi-Fi icon displayed on the screen.
  3. Choose Your Network
    • From the list of available networks, select your Wi-Fi network.
  4. Enter Password
    • Input the Wi-Fi password when prompted.
  5. Confirm Connection
    • Follow any additional prompts to complete the connection process.
Troubleshooting Tips
  • If the printer does not find your network, ensure that your Wi-Fi is functioning properly and that the printer is not too far from the router.
  • Restart the printer and try the connection process again if you encounter issues.
By following these steps, you should be able to successfully connect your PIXMA G3520 to your Wi-Fi network using the printer panel.
