05-03-2026
02:31 PM
03:11 PM
StevenMOD
Hello, is there a way to record 2 different camera profiles on the XF605? So it would be nice to record CLog3 on one card and Wide DR on the other card.
05-06-2026 05:58 PM
Greetings JCin,
The Canon XF605 does support dual recording to both SD card slots simultaneously, and it is technically limited to using the same Custom Picture profile for both recordings. While you can record in different formats or resolutions (such as 4K on card A and HD on card B), the internal image processing applies your selected gamma curve, like Canon Log 3 or Wide DR, to the entire video signal before it is saved to the cards.
05-06-2026 05:58 PM
Greetings JCin,
