11-30-2020 10:03 AM - edited 11-30-2020 11:20 AM
Any idea when a Big Sur compatible version of Print Studio Pro will become available? Tried to download and install ver 2.2.4 and it will not install. Anyone have a workaround to use PSP plugin with Lightroom and Photoshop? Thanks
I have a Apple iMac with a Canon Pixma Pro 100
11-30-2020 10:29 AM
Welcome to the Canon forum!
So that the Community can help you better, we will need to know what model Canon
equipment you are using. Any other details you'd like to give will only help the Community better understand your issue. If this is a time-sensitive matter, click HERE search our knowledge base or find additional support options HERE.
12-12-2020 05:08 AM
I'm using a Canon Pixma Pro 10S on the latest firmware, Mac OS Big Sur (11.0.1), and Lightroom Classic 10.1 Release.
I now have the same issue as the OP.
Prior to updating MacOS and LRC your Studio Pro plugin was working, after updating I cannot seem to install it again and get a failed message each time I try.
My guess is it needs to be updated. As I can see when selecting Big Sur on your support page, Studio Pro is not listed anymore.
Any idea when that is going to be?
Thanks!
Phil
11-30-2020 01:00 PM
It works for me.
Do you have the IJ Series version of the printer driver installed?
11-30-2020 01:46 PM
I do have the IJ driver installed for the printer that corresponds to Big Sur OS. I'm getting a "This Installation failed" message when trying to install 2.2.4 PSP.
11-30-2020 02:05 PM - edited 11-30-2020 02:10 PM
I just re-ran the installer app and the window I get says Lightroom found. Give canon a call at 1-800-OK-CANON.
Check your Private Messages.
12-01-2020 04:32 PM
Did you install 2.2.4 on an Imac with Big Sur? I keep trying and get the error message Installation Failed....
12-01-2020 04:49 PM
Yes. Big Sur and 2.2.4.
12-05-2020 01:13 PM - edited 12-05-2020 02:27 PM
I just got a Pro-100 and when I go to this page
(selecting Big Sur)... Print Studio Pro is not available. So, when will it be? And how come it seems to be working already for others on this thread?
12-05-2020 02:09 PM
Welcome to the forum Jenna.
The issue seems to relate to the installer, not the actual app itself.
In my case I already had it installed with Catalina, so I was all set.
https://1drv.ms/u/s!ApNpngg2Z6dbg8ogEOgVEjNactdzeg?e=nRyDTy
This link has the PSP file folder and a graphic of where to install it.
I can only help with Photoshop since I am unable to find where LrC has the module folder on the Mac.
