01-09-2023
01:23 PM
10:46 AM
Seems like whenever I print this design or other similar designs, there is an odd purple discoloration/streaks that are getting super frustrating! Original color is like a dark beige. Ive tried everything I know.
01-09-2023 01:41 PM
Hi kativishna!
To have a better understanding of your issue, please let everyone know the operating system on your computer as well as what program you are printing from. Any other details you'd like to give will only help the Community better understand your issue.
If this is a time-sensitive matter, please check out your other support options here: https://canon.us/MyCanonAccount
Thanks!
01-09-2023 02:42 PM
Canon pro 1000
01-10-2023 10:46 AM
Thanks for confirming which model you're using, though the question was what operating system you're using on your computer (i.e. Windows or macOS, and which version thereof) and which application you're printing from. That would help the community figure out a solution for you.
We look forward to your reply!
01-10-2023 11:05 PM
Im printing from a Mac version 11 and using photoshop! 🙂 Thanks for your help!
09-14-2023 06:48 AM
Same problem here. I use Windows 11 and Lightroom / Proffesional Print and Layout. It happens independent of paper choice, paper size or whether I print USB / Wifi / LAN
09-19-2023 12:33 PM
Does this happen with this picture file only or are you seeing this issue with any photo you print?
09-20-2023 05:47 AM - edited 09-20-2023 05:49 AM
Hi, it happens on any photo, regardless of color or b/w, ICC profile, paper, or whether I print from Canon Professional Print and Layout or Mirage printing software
09-20-2023 11:24 AM
At this time recommend you reach out to Canon support. You will need to register your Canon gear HERE to access additional support options.
We look forward to hearing from you.
09-30-2023 05:50 AM
Hi, did you please manage to get this sorted? I'm having the same issue and at a loss! Tried all the cleaning cycles and really desperately need to use the printer. Let me know if anything has worked for you, thank you so much
