05-19-2025 11:15 AM
Hello! Any help would be greatly appreciated!
Cheers,
By the end of April, I had completed the proofing process and was ready for production on a 5 x 7 greeting card. The final proofed master file was printed with these settings:
I installed two updates early last week:
Three errors are now occurring and I have not been able to clear them:
Troubleshooting I’ve done so far:
05-19-2025 03:52 PM
Okay, so far this seems to have worked:
1) I manually select paper settings on the printer
2) Installed the Canon Professional Print & Layout, THEN manually install the PPL plugin, into the Ps application plugin folder.
In shop, open the file you want to print, then go to File -> automate -> you'll see the PPL plugin.
I still don't know why I was able to directly print from Ps, and then suddenly wasn't able to, but I'll have to spend time figuring that out later.
05-19-2025 03:20 PM
I have a Pro-100, but your printer might be the same. Access the Printer Utility via System Settings-Printers & Scanners.
You didn't mention this, but did you try reinstalling the printer driver?
05-19-2025 03:52 PM
05-19-2025 03:54 PM
Thanks John! I was able to figure out how to print directly from the Canon PPL plugin through shop.
Appreciate you taking the time to help me troubleshoot this!
