Professional Photo Printers
How to Get the Most from Canon’s Software Tools for its Professional Inkjet Photo Printers Getting a print to match what you see on screen isn’t magic - it’s a process. And a big part of that process happens in the software. Whether you’re using the...
ccanada by Administrator
  • 3168 Views
  • 0 replies
  • 1 likes
General Resolution Value in Photoshop
I just was told that the Pro-100 should generally be set to a resolution of 300 in Adobe Photoshop for printing.  Notice the key word here, "generally."  Not looking to spark a debate on "if-this" or "if-that" regarding the hundreds of possible circu...
DarylGS by Apprentice
  • 4609 Views
SHEET CLEANING, ix7000
To avoid what I just went through, check to see if you already have the cleaning sheets. They apparently came with my printer and are located in an obscure drawer. Pull out the bottom paper tray, turn the tray so the right side is facing you. Look fo...
katbrain by Apprentice
  • 6746 Views
  • 0 replies
  • 1 likes
PixmaPro9000 is misbehaving
Dear people,My PixmaPro9000 is misbehaving. All ink cartridges are installed, full according to the printer driver, and in the correct order, with airholes uncovered. The printer previously printed photos fine, but has been rarely used for a couple o...
jcn by Apprentice
  • 5817 Views
  • 3 replies
Pro9000 MarkII PM ink is clogged
 Only the PM ink is clogged even after cleaning and deep cleaning and new ink. I have even wiped the contact pad under the cartridge with a cotton tip. I am using non-Canon ink! Is repair next? Thanks.
Reliceye by Apprentice
  • 4067 Views
Print Studio Pro plugin
I  would like to use this plugin with Paintshop Pro (my image editor for over a decade).  The plugin works with all the Adobe products, but I'd rather not tether myself to their marketing model. Most Photoshop plugins work in PSP, is there a way  to ...
Resolved! Print Studio Pro?
I have purchased PRO-100 just resently. Here and there I see references to Print Studio Pro. I fiqure by the way they talk about it that it might be a program or plug in. Anyway when I installed the software and even re installed the part called Prin...
otava by Enthusiast
  • 4084 Views
Canon i9950 print issue
When I do a test print or alignment test there is no green output. Yet when I print pictures with green in it looks fine, Also, on the print head alignment print the cyan has lines in every regtangle, not one is solid colour. I have run the print hea...
Wingston by Apprentice
  • 4177 Views
Questions before I purchase a Pixma Pro-100
Haven't spent any time over here on the printer side of the forum and I didn't see my questions posted so I will post them here hoping they aren't repeat questions.  Been researching photo printers and found the Pixma Pro-100 to suit my needs.  This ...
7D5D by Rising Star
  • 11862 Views
  • 8 replies
