Replace more than one ink cartridge at a time? (Pixma Pro-100)
aaron1556
I have a Pixma Pro-100.  I've not used it much so I've never had to replace ink cartridges until now. All cartridges are showing at least half empty. A couple of them are getting the warning for low ink. I have replacement cartridges for all ink.
Here's my question: According to Canon's documentation, you're only supposed to replace one ink cartridge at a time. However, I've read that that wastes ink since the printer cycles through cleaning or something or other each time a cartridge is replaced. So, can I replace both low cartridges at the same time, or should I stick with the documentation and replace each one individually? Anyone replaced multiple cartridges at once, and did it cause any trouble?
Thanks
4 REPLIES 4
smith88j
You can replace them both at the same time.
Thanks. Any idea of there's an economical advantage to replacing two or more at the same time--perhaps even if one is not yet completely empty?
I personally don't swap out until they are empty. Ink is too expensive to throw away.
jrhoffman75
I've never seen/noticed the caveat about replacing only one at a time. I have replaced more than one at a time; no problems.
Maybe it's just a precaution to make sure someone doesn't put wrong cartridge in a location if two or more locations are empty.
