01-09-2015 02:24 AM - edited 01-09-2015 02:25 AM
Hello all!
I have several Canon Pro9000 and Pro9000 Mark II printers. The Pro9000 Mark II printers are doing great. However, the Pro9000 printer is printing photos with a heavy blue cast to them. The blue is so heavy and so bad that any photo printed with it is destroyed.
I have tried printing both from Photoshop and from other programs, including straight from Window's photo viewer. When printing from Photoshop, I have tried both letting Photoshop manage colors and the printer manage colors. When Photoshop is managing colors, I've turn color management off for the printer (set it to None). I've made sure I have the proper paper selected, etc. It does not matter what I do, the Pro9000 still prints with a heavy blue cast.
I've tried switching from Auto to Manual in an attempt to reduce the blue. But even if I have the first slider (labeled Cyan) slid all the way to the red side and the third slider (labeled Yellow) slid all the way over to yellow, I am still getting a heavy blue, but now the images are too red and too yellow, etc.
What can I do to figure out what is going on with this printer? It used to print properly, so I am not sure what changed. Any help would be much appreciated.
Thank you.
PS - I am running Windows 8.1, 64-bit.
01-09-2015 03:44 PM
01-09-2015 04:06 PM
Am I to understand, two different printers? Several computers? Plus any software doesn't matter?
You do know how impossibile this is?
You have a bad supply of ink. Are you using genuine Canon ink? Or, I am back to my first thought, the print heads have failed.
01-09-2015 03:43 PM
01-09-2015 11:11 AM
01-09-2015 11:14 AM - edited 01-09-2015 11:15 AM
Certainly, there were new pieces of software installed. But I don't think this is the issue. I am getting the same results whether I print from my desktop PC or the laptop that I take to events with me (though I am going to check that again later today just to be sure). The laptop PC is dedicated only to event printing. As a result, it has not had any new software installed since this started to happen with the Pro9000's.
01-09-2015 11:27 AM
01-09-2015 03:44 PM
01-09-2015 03:45 PM
01-09-2015 03:48 PM
01-09-2015 03:50 PM
01-09-2015 04:06 PM
01-09-2015 04:09 PM
