12-18-2023
04:35 PM
07:54 AM
James_C
I have been using Canon Pixma Pro 100 up until a few days ago… but it's finally given up on me so I'm now using a Canon Pixma Pro 200. I'm having issues with printing the colour Pink. It comes out a very definite purple. I have downloaded the ICC profile for the paper I'm using and have ignored the printer settings and selected appropriate Photoshop settings instead. The only workaround I have found is to adjust the pink colour in Photoshop by changing the hue/ saturation. But this has meant a lot of experimenting and wasting a lot of good paper and ink. I have even tried printing from my desktop Mac (I had previously been printing wirelessly from my MacBook Air) and using the USB cable (after seeing a thread about USB printing. having better results). Both give the same purple colour instead of pink. Please tell me there is an easy solution? The Pro 100 just worked perfectly! I never had any issues with colours when using that printer.
02-26-2025 11:07 PM
Did you ever get a solution. I have the Pro 200 (purchased in December) and my pinks print purple. I have done every suggestion nothing works. I used the same computer same, print program on my other canon and it prints perfectly
02-27-2025 03:45 AM
Sadly I have never found a decent solution. On a few occasions I've just had to play about with hue / saturation to compensate for the issue. Which obviously isn't ideal and takes a lot of trial and error to get something to work… Not the cheapest way to resolve the issue either as you waste ink and paper in the process. Sorry! Really frustrating.
02-27-2025 05:59 AM
1. print a nozzle check.
2. print this test image and see how it looks. Do not make any adjustments regardless of how it looks on screen.
PrinterEvaluationImage_V002_ProPhoto.tif
3. post phone shots of the results of both.
03-24-2026 01:56 PM
Hey… I know it's been a while. Not sure if you ever found a solution. It's taken me til now to find a way around the issue. I have started saving my Photoshop files as PDF's and find that printing from Acrobat means I can print the PINK pretty accurately now (no longer purple!). Got to be the most infuriating issue I've ever encountered… frustrating that every other colour prints fine… and for some reason it's just pink that it doesn't seem to like. I know it's not a perfect solution but might be worth a try if you're still having the same problem.
