11-09-2022 02:24 PM
My print dialogue box doesn’t show all the options. I don’t have any color options and the Quality Media setting is different - it doesn’t have media type listed. The show details box is activated. I’m using a Mac book pro running Monterey 12.6 and printing from Light Room Classic. I think I’m missing a setting somewhere that needs to be changed. Any help would be greatly appreciated.
11-10-2022 03:19 PM
Hi sueb500! Thanks for posting in the Canon Community Forum. I see that you do not have access to some of the print settings (color and media) for your imagePROGRAF PRO-300.
There may be an issue with the CUPS Printer Driver that is installed on your computer. It’s also possible that your computer is not using the CUPS Printer driver properly. For that reason, I recommend reinstalling the driver, deleting the printer, and adding a new copy.
To install/reinstall the driver, please follow these instructions:
When the driver has finished installing, please delete the printer by doing the following:
When the printer is no longer listed, please add a new copy using these instructions:
After you follow these steps, you should have all the print options available when you go to print.
Please post again should you continue to need help.
I hope this information helps. Thanks again.
11-10-2022 03:19 PM
11-11-2022 01:50 PM
Thank you so much!!!!! It worked!!!!!!
