02-04-2023 04:19 PM
Hi there, I have a Canon pixma pro-200 and am trying to test print some illustrations to check colors. I'm printing through Photoshop using a macstudio. When I try to print using Photoshop settings, it tells me to make sure to disable the printer's color management in print settings but I do not see any settings there to allow me to disable. I checked my printer's settings in preferences and saw that it is using Canon Pro-200 series-Airprint. I removed the printer and added it again using Canon Pro-200 series in the 'use' dropdown. But when I go back to check it, the Canon Pro-200 series - Airprint with driver verwsion 3.0 is listed again.
Not sure how to solve this issue but if anyone has any suggestions, I'd be greatful!
Thank you,
Janeen
02-07-2023 01:23 PM
When you add the printer back in Printers and Scanners, do you get both AirPrint and Pro-200 IJ Network?
11-17-2023 03:28 AM
I am having above issue i keep deleting and installing and when I go to add orinters I only see a single option for canon pro 200 series I dont see anything at all mention air print of IJ. If I choose other software dropdown all i see are other printers like HP/Epson. I am unable to complete orders because i have no color dialogue. This is in Mac sonoma 14 OS
11-17-2023 01:47 PM
Did you install this driver from the Canon support page?
04-22-2024 07:48 AM
Hi John
I'm having the same issue (running same operating systems). I have tried to install the CUPS driver to solve it- I'm able to go through the whole process and it says successfully installed. However then when I get to step 3 in the setup, I'm shown this error message that says I need to install the canon driver first.
Unsure where to go from here, just want to be able to print from the driver instead of AirPrint so I'm able to use the utility tab to make changes. Came here from trying to implement these fixes shown on this other community page here.
Thank you for any insight you can offer!
04-22-2024 08:23 AM
Hi. I have never gotten that error message, so cannot help. You should register your product and contact Canon for support.
05-13-2025 10:38 AM
Hi, wondering if anyone has been able to solve this problem?
I am facing the exact same issues and cannot get the printer driver to install and the printer continues to default to AirPrint. I've added and removed my printer (Pixma Pro 200) multiple times and nothing seems to be working.
Any help is much appreciated!
05-13-2025 10:53 AM
Give Canon support a call at 1-800-OK-CANON.
