09-13-2021 12:18 PM - edited 09-13-2021 12:35 PM
Hello,
I've been trying to get rid of the slight magenta cast on my prints for days. I have a Mac that's running Catalina 10.15.7 and printing through Photoshop CC (updated). I've read through many of these forums and tried everything, with no luck. I have a hunch it's double profiling but can't get it to stop. Please help!
I've tried:
When that didn't work I also tried
Which didn't work.
Any other suggestions? Thank you in advance!
Kate
09-13-2021 10:28 PM
09-13-2021 11:22 PM
09-14-2021 07:15 AM
Hi Kate.
I agree that magenta cast sometimes indicates double profiling, but 1. the settings you posted all looked correct and 2. PSP definitely provides the proper setting, so that is confusing.
A few thoughts to try:
1. for test purposes can you connect the printer via USB?
2. check that all the plastic wrap is removed from the top of the cartridges. There is a little vent hole on top to let air in. If that is obstructed it won't necessary affect a nozzle check (very little ink) but could affect a print.
3. download and print the test image from this site. Don not make any adjustments, just open the image and print.
Printing Insights #49 (outbackphoto.com)
09-14-2021 03:08 PM
Hi John,
1. The magenta cast is present in USB printed images.
2. There's no plastic on the cartridges.
3. I downloaded and printed the test images, which most notably showed the sky in the arches photo with a lack of cyan, it seems? It also generally looks flat. Apologies for the poor quality, the image file was quite small.
Any further ideas?
09-14-2021 03:52 PM
It does look like the cyan may be a little weak compared to the test image.
The magenta cast you are seeing is not what I would expect from double profiling.
Are you using the Print Preview option? That sometimes messes up the ICC profile selection.
The only thing I can suggest is to really look closely at the nozzle check vs the Canon image of a good check.
Other than that, maybe a call to Canon at 1-800-OK-CANON.
12-13-2021 07:47 AM
I've had same issue - which seems to happen despite any alterations to profiles or manual settings. I have had the same workflow for over a year & had satisfactory results printing in monochrome. I used the 'print preview' option once & since then I cannot get rid of a pronounced magenta case when using 'Plain Paper'. Is there a fix to this glitch - I have deactivated the preview option, but the issue continues. I can print in monochrome on 'plain' paper with Mac without this issue - it seems to be a Windows 10 / Canon issue?
12-13-2021 08:07 AM
When thinks get out of whack sometimes reinstalling the driver sorts things out.
I have a Pro-100 (not Pro-10) but have no problems with W10 printing.
macOS automatically prevents double profiling, but since you said you were previously successful you know how to disable color management in Windows.
12-13-2021 08:12 AM
Unfortunately uninstalling / reinstalling driver & latest updates has not solved the issue. It also persists when I switch to a Windows 10 laptop - which suggests the glitch has somehow registered on the printer's side?
12-13-2021 09:34 AM
Maybe a factory reset then?
https://www.techwalla.com/articles/how-to-perform-a-hard-reset-on-a-canon-printer
