06-07-2015 11:16 PM
I tried printing at the 13x19 format for the first time and doing everything im supposed to do.. Lift the front tray, hit the blue button so I can insert the paper, align the paper to the white line, hit the button again, it slides the paper to the back of the printer. I hit the print button in lightroom and it lights the amber light 10 times which says the front tray
Support Code : 1281 Printing cannot be executed with the front tray in its current position. 1. Return the front tray to its normal printing position. 2. Press the printer's RESUME button to restart printing.
But I havent moved anything so how can this be?
06-09-2015 08:47 AM
Just guessing but I bet you have something set wrong in LR.
13x19 is no different that any other size. It will print just like they all do. And using the same loading procedure.
Are you using the loading area at the top back of the printer? And do you have the extensions open?
06-09-2015 11:50 AM
Agree. Check that you have Manual Feed checked for the paper source.
06-09-2015 11:58 AM
