08-04-2023 09:53 PM
Hello,
I'm having a weird problem and not having much luck with trouble-shooting. I have two computers that connect to my Canon PRO-300 for printing. I made one successful print today, but cannot print any more - the file is sent to the queue and sits there with printer status on "standby". The printer is not displaying any error messages (or any messages at all).
One computer is a desktop running MacOS Sierra 10.12.6. The other is a laptop running MacOS Monterey 12.6.7. I have restarted both computers and discharged power on the printer and restarted it as well. The printer is connected to the wifi router with a wired LAN connection. The printout for the LAN connection says the printer does not have a connection problem.
Any suggestions welcome!
Chris
12-22-2024 12:58 PM
In case this helps anybody, I was having the same problem. I realized it was my VPN that was changing my IP. So after turning the VPN off, the issue was fixed.
08-09-2023 03:31 PM
Please click HERE for the steps to print the network settings page from your printer. Once it prints, please reply to the following:
Also, open a web browser on your computer, and in the address bar, please type the IP Address on the configuration page into the address bar. Next, tap Go or Enter to access the page. Are you able to see the printer's remote interface?
If you would like to speak to someone live about this issue, you will need to register your Canon gear HERE to access additional support options.
08-10-2023 05:44 PM
Hello,
There were no answers to your 3 questions in the network printout sheet because it is a *wired* LAN connection. However, I did find out that the printer's IP address was not showing up in my router's list of connected devices. Having determined this, I unplugged and replugged the connecting cable (which I had also tried on the day of the problem). It seems to have been fixed for now.
Thank you.
12-22-2024 12:58 PM
