11-25-2015 09:31 AM
I have a Canaon PRO-100 that continually needs to be deep cleaned if I forget to do a print at least every day or 2 times a day, also it says ink tanks are empty even though they are FULL or nearly so, what is the problem, I have read that this is a known problem with Canon PRO-100's is there a solution?
11-27-2015 11:19 AM
I have never done that. I have two Pro-100's. Are you using real Canon branded ink? If not do so.
11-27-2015 02:59 PM
Hello.
Please ensure that you are using new, genuine Canon brand ink tanks. Refilled or 3rd party inks may not be detected properly.
If you are using genuine Canon brand inks and the issue persists, find more help at Contact Us.
11-28-2015 11:32 AM - edited 11-28-2015 11:40 AM
Put brand NEW Canon cartridge in 3 days prior, used it once or twice, next time I went to use it, it said it was empty, still full of liquid ink and sponge was full also, this is not the first time this has happened. I only use genuine Canon Ink.
11-28-2015 12:15 PM
Call Canon support. That is not normal.
11-28-2015 12:45 PM
This time as the last, put new tank in and it says all is OK.
12-03-2015 09:51 AM
My unit is out of warrenty, they don't care.
12-03-2015 10:20 AM
"... they don't care."
They will still help you. There is a point where every company has to stop "warranty" claims. But warranty or not Canon is one of the best for customer support. They will still help you.
If you call and get crumdungen, hang up and call back.
12-03-2015 11:37 AM - edited 12-03-2015 11:38 AM
ebiggs1 Read my relply above
12-03-2015 10:48 AM - edited 12-03-2015 11:39 AM
just spent 35 minutes on the phone with Canon Support, no solutions offered other than, buy a new printer, take it in to canon service location where the basic charge is more than the cost of buying a new printer, or buy a non refundable non returnable print head that will cost more than 1/2 the price of a new printer and probabily won't fix the problem,so no real solution offered. So I guess that leaves only one solution,I will throw it away and buy a new printer.
