09-05-2014 12:51 PM
I'm sure I'm doing something wrong but I just set up my brand new Pro-100 printers using Canon ink and paper and the prints are coming out very wet and runny. I print from Lightroom. Am I missing a setting somewhere?
Thanks!
09-08-2014 09:32 AM
Thanks everybody. I tried a different paper and that solved the issue so either I was printing the wrong side of the first paper (since it doesn't have a watermark on the back) or the paper is the issue. I would bet I was printing on the wrong side.
Thanks again, all is well!
09-08-2014 08:00 AM
This is the way I have my printer set for the Canon Luster paper that came with it. I even increased the drying time to max. The prints come out so wet that the colors run and becomes a big mess. I am printing on the glossy side of the paper.
09-08-2014 08:15 AM
09-08-2014 09:32 AM
10-19-2014 06:00 PM
I am having the same problem as you I used both sides of the Canon luster paper still comes out the same wet and the ink starts running into each other making a mess. I used Matte paper and the colors do not run. I want to use a paper with luster but I keep wasting ink and paper.
Joe
10-19-2014 06:13 PM - edited 10-19-2014 07:06 PM
If it works OK with matte then it's most likely not the printer. Doublecheck that you're selecting the correct paper profile.
10-19-2014 08:32 PM
10-19-2014 09:14 PM
10-20-2014 08:54 AM
Yes, John is correct. I was printing the wrong side. Everything works perfectly now.
10-20-2014 09:14 AM
"... I used both sides of the Canon luster paper ..."
It is the whiter side of the paper. Never use the back as it will not absorb the ink. This causes a big mess inside the printer. Also you must have a wrong profile selected.
In most programs you must check this each and every time you print. Some softwares do not remember what you did last time.
Check your profile, it is wrong for that paper.
10-20-2014 06:01 PM
I did not have the correct setting. I did not check apply to my printer setup in control panel.
Joe
