Canon Pro-4000 Immediately Runs out of Ink for PBK
nik_lockett
My Canon-4000 PBK ink keeps running out immediately after loading in a new ink cartridge.  The printer makes a gurgling noise after loading the new cartridge like the ink is going somewhere and draining from the cartridge.  Then, next time I go to print something I get a message that the ink tank is empty.  I loaded in two 160mL Canon PFI-1100 Photo Black Pigment Ink Tank cartridges and have experienced this back-to-back.  When I run a test print page, all the ink tanks are printing.  When I run a print job, the printer stops printing the job due to the PBK Ink showing empty.  When I inspect the cartridge and shake it, it appears to be empty although full when I loaded them into the printer.  Please help me understand what could be happening and suggestions on ways to resolve.
18 REPLIES 18
Hello Eric,
They upgrade the printer software, version is 02.19.
After they changed the whole unit and all the left cartridges without charge for the spare parts.
But in the mean time after the software upgrade (3 weeks) the problem didn't occur.
Hope it will help.
I updated the firmware, but now I suspect that I have (2) 700ml ink cartridges of ink pooling in that area.  How did you get to that section in the printer?
Sorry, but I don’t believe your issue was a leaky sub tank, a software update will not repair a leaking sub tank, it can’t be fixed, only replaced.
Think about it logically, how on earth can a software update repair a leaking sub tank, I don’t understand why people reply with bs just to sound like they know what they are talking about, all their doing is giving people a false hope, it’s a consumable part that can only be replaced, not reliably repaired, and no software update with fix a broken seal
drscotti
Anyone have a fix?
Hello, the issue is with the grommet / valve on the underside of the sub ink tanks, gets weakened after the many cycles of use, causes a tiny hole which air gets in and allows ink to leak out, air goes into the cartridges so their not vacuum sealed which is why when you put a new cartridge in it empties in days “if your lucky” it’s a part that should cost pennies to fix I’ll attach pics of the culprit, either buy a wrecked machine and strip for grommets, or my solution I built an automatic ciss bulk ink system bypassing the factory sub ink system
Tscheidt
Solved it.  The guy in this video found where the leak comes from and if you do the same break down then find the pin hole in the diaphragm you can plug it with some marine glue applied via toothpick to hole then reverse the process and rebuild.  https://youtu.be/7W4Q5e7Ku18?si=ZUWA_VhJclt0kYPa
Yah see above.
Marine glue and a toothpick to apply fixed it for me.  Also using a leak hunt and tear down video I posted link to above.
