03-03-2025 04:35 AM
The last time I replaced the toner cartridges in my Canon Color ImageCLASS MF632Cdw, I thought I'd save money by buying third-party toner instead of genuine Canon toner.
My printouts were fine at first but after a while they started looking worse and worse. I eventually replaced just the black toner with genuine Canon toner and the black parts of my prints were immediately perfect, as they have remained for many months.
Meanwhile, the color parts of my prints were continuing to get worse. I'm here to ask if you think the third-party toner is causing the ugliness in the attached graphics, or if it could be something else. I could buy genuine C, M, & Y Canon toner if necessary -- but it's SO expensive!
I've gone to the Maintenance screen on the printer and went through the Clean Fixing Assembly, the Clean ITB, and the Clean Feeder procedures more than once (although today several attempts trying the Clean Feeder procedure did nothing).
Here are two dual graphics: the first half of each graphic is the original file and the second half is a scan of the printout of those files:
#1 • Original file, then my printout
#2 • Original file, then my printout
Since I bought the printer (new) about 7-1/2 years ago, it seems to be that I've only printed 2,290 pages.
Many thanks!
03-03-2025 04:11 PM - edited 03-03-2025 04:14 PM
I doubt anyone here, nor Canon, help you with image problems when you install third party toner. Whether OEM toner will solve the problem now, or whether there is other damage, we can't know. You save money with third party toner, but you take your chances. Considering that you printed a grand total of only 2,290 pages the money you saved per year over 7 1/2 years will be negligible compared to the cost of new printer.
03-03-2025 04:17 PM
Many thanks! I’ll bite the bullet and replace the toner with genuine Canon toner. It’s not really saving money when the output is virtually unusable. I appreciate your advice!
03-03-2025 04:25 PM
What I have learned the hard way is, you want cheap, go with inkjet. If you take the dip into color laser, either be prepared to do the full plunge, or reconsider. There seem to be 20 brands of third party laser toner for these Canon models. Some people say they find success, many do not, and many don't find out for a while.
Btw, if you buy the toner directly from the Canon website they usually have a discount for purchase of more than one, any color.
03-03-2025 04:58 PM
Inkjet is a MORE expensive way to print. On the other hand, it is superior to laser for photo printing.
There are good aftermarket suppliers of laser toner......who don't recycle the toner/drum units endlessly. This could be the problem with yours. I don't know if I can tell you on here who I use but if you private-message me I'll tell you. Their product gives me top results on my aging ImageClass MF8350cdn and a Brother printer. Also Canon and Brother inkjets.
03-03-2025 11:11 PM
More expensive on a cost per page if you do a lot of printing, but you have to consider that for many people they can easily go to Best Buy or Amazon, and they're printing for $100. Can't do that with color laser printing.
03-04-2025 01:45 AM - edited 03-04-2025 01:47 AM
Cost per page is cost per page, small volume or large volume.
An inkjet printer that costs only $100.00 (even down to $59.00) is a poor investment. Probably has tri-color cartridge which is wasteful when one of the colors runs out. Cartridges don't hold much ink. Possibly limited in photo print size (for example, borderless only up to 4x6 or 5x7). Replacing ink cartridges cost as much as buying another printer. Purchasers of these things frequently write in to this forum expressing disappointment.
