To be honest, we have had issues with this printer from day 1. It is the Color Image Class Mf644Cdw. We do not use it often, as we only use it for printed materials for funeral services. The latest issue is none of our computers can connect to it, ev...
Hi!! Does anyone have step by step instructions on connecting Pixma iX6820 to an iPhone's personal hotspot? I'd like to be able to print at flea markets without wifi. Thank you!!
The printer has previously connected to the WiFi. (This is not my first Canon printer of this type.) The printer sees the available networks but after entering the network key the printer fails to connect. I have gone to “other connections” and used ...
Hi, I have the Pixma G3260 printer/scanner. I recently moved and switched over my wifi network. On the printer / scanner console, I manually moved changed it over to the new wifi. I've been able to successfully print over wifi from my mac. Howeve...
I have a Canon G6020 associated with my iMac... I set up AirPrint from that printer to my iPad and iPhone, and it's been working for a year or two, but just recently it won't work, and I don't know how to get it back. It acts like it's working when I...
I had a Windows 10 machine and the print preview worked fine.After upgrading to Windows 11 (and a new machine) the [Windows 64bit] UFR II Printer Driver V30.30 was installed. Now I get the error "This app doesn't support print preview."How do I get p...
TR7020a printer will not connect to any of our computers or phones. I have installed the latest drivers and the WI-FI setup help driver. The printer is connected to the Wi-Fi and the computers are connected to the same WI-FI, but the error messages...
I have a Canon LBP6030w printer. I changed Internet providers recently, and all devices work perfectly, except the printer. I need to change the User Name and Password (or Network Key) to the new sign-in. I have a MacBook Pro, as well as a PC, and...
I have a Canon lbp6230dw printer that had worked well but when I updated the operating system on a Mac Air M1 2020 to Sonoma 14.6.1, the printer stopped working. I updated the printer driver and software to 1.15.13 but it doesn't work either, it does...
Hello, I try to connect my printer CANON LBP7210C/7018C but I got the message : "The port to which the printer is connected is not supported.Check the port." The printer is connected to a router, and I'm using windows 11. I am not using a firewall w...
Two weeks prior to this, I reset my Canon TS6420a printer due to it not printing double-sided while setting it to do so on both the printer and device. Tonight I tried to reconnect it to wifi through the Canon PRINT app on a Chromebook. While it woul...
I have been utilizing my printer for several months. Today I am receiving messages that no print driver found. when I go into Canon trying to download a new driver, I am being told there is no driver for my OS. Why when this has been communicating...
I purchased a new TR4722 printer today. When I try to download the setup file to connect the printer to my PC, the file fails to execute. Is there a canon support number that I can call to get help?
Can I update my TR8520 software to use with my MACOS Sequoia 15.5? If so, how do I do so?
| Subject | Author | Posted |
| 09-15-2026 07:21 PM | ||
| 09-13-2026 07:01 PM | ||
| 09-10-2026 02:37 PM | ||
| 08-14-2026 05:48 PM | ||
| 04-28-2026 08:20 AM |
