For Mac, IJ Scan Utility Lite not able to find PIXMA G3260 scanner on Wifi
JimSc
Hi, I have the Pixma G3260 printer/scanner.  I recently moved and switched over my wifi network.  On the printer / scanner console, I manually moved changed it over to the new wifi.  I've been able to successfully print over wifi from my mac.  However, when I try to scan via the IJ Scan Utility Lite, it can not find the scanner on the network.  I don't see any place in the IJ Scan Utility Lite where I can see or change what wifi network it is trying to look for the scanner on.  Any help is appreciated!  Thank you!
1 REPLY 1
Rockenator
The Canon scanning software as well the Canon Remote UI is utterly garbage.  Whoever developed this POS should be fired, immediately.  Best workaround?  At least for a Windows PC - NAPS2 Software Scan Utility.  Freeware (make a donation as it really works great!)  I wasted a hour or so with Canon's archaic Remote UI and MF Scan.  Found NAPS2 and I'm not looking back.
