04-21-2022 10:49 AM
I am having problems starting Print Studio Pro (PSP) as a plug-in to Adobe Lightroom Classic (ALC). I can download and install PSP without any problems or errors being displayed and I can install it as a plug-in to ALC without any errors. However, when I try to launch PSP from ALC I get the following error: "Windows cannot find 'C:\Program Files\Canon\Print Studio Pro\CNPSPPILR.lrdevplugin\CNPSPOPN.exe'. Make sure you typed the name correctly, and then try again."
I tried unplugging PSP from ALC, uninstalling PSP, redownloading PSP (in one case I downloaded it from the alternate Hong Kong site), installing PSP, and plugging in PSP to ALC several times without success. I even restarted windows after installing PSP in one case. It didn't help.
I did check to see if PSP was installed at the location mentioned in the error dialog and it was; however, the CNPSPOPN.exe executable file was not in the CNPSPPILR.lrdevplugin subdirectory. It was in the next directory up: C:\Program Files\Canon\Print Studio Pro.
My system particulars:
Lightroom Classic: 11.3 Release/Camera Raw 14.3/Build 202204051513-7a25c809
Print Studio Pro: 2.2.3
Windows 11: 21H2 (OS Build 22000.613)
Anyone with pointers on resolving my problem would be greatly appreciated.
04-28-2022 11:44 AM
I have found my solution after researching a couple of non Canon blogs. What I found is the installation instructions from Canon are woefully lacking and each of the solutions recommended in the blogs where lacking in different areas. I put together an amalgam of correct steps to get me to the solution that works:
How to Install Canon Print Studio Pro in Lightroom Classic on a Windows Machine
https://www.canon.com.cy/printers/inkjet/pixma/software/print-studio-pro/ or
https://hk.canon/en/support/0200493210
Linking as Plug-In in Lightroom
07-20-2022 11:55 PM
I have a new Canon Pro-300 on a Mac Pro M1 MacBook. When I try to use Print Studio Pro from Lightroom Class, it throws an error saying that my Pro-300 is not supported.
Has anyone else had this problem? How can it be corrected?
Thanks,
Dan.
p.s. Using the standard Lightroom print utility, it prints fine.
07-21-2022 06:42 AM
@Bookemdanno wrote:I have a new Canon Pro-300 on a Mac Pro M1 MacBook. When I try to use Print Studio Pro from Lightroom Class, it throws an error saying that my Pro-300 is not supported.
Thanks,
Dan.
For the Pro-300 you should download Professional Print & Layout.
07-21-2022 11:59 AM
Thanks John. I'll give that a try.
07-21-2022 01:09 PM
John,
PPL is installed. However, when I try to use the stand-alone or plugin versions of PPL, it does not see my Pro-300 when I click "Find Printer" in the "Add Printer" window. What's worse is that the app closes immediately if you don't add a printer. Catch 22.
I sincerely hope Canon understands how badly this reflects on Canon and its products.
Regards,
Dan.
07-21-2022 03:12 PM
Give Canon a call at 1-800-OK-CANON.
07-21-2022 04:08 PM
John,
Thanks, I'll give them a call.
FYI, I was able to get the Media Configuration Tool to work after setting up the Pro-300 to use WiFi to connect to my network. PPL STILL does not work.
Regards,
Dan
07-21-2022 06:30 PM
I spent over an hour with Canon Support. Barbara gave it her all, but nothing worked to get PPL to see my Pro 300. She is reporting the issue to their software developers.
As a side note, I got the Media Configuration Tool to see my Pro 300 using an ethernet connection.
So the issue is specific to PPL.
Regards,
Dan.
07-21-2022 08:55 PM
DPReview has a Printer forum and Fred Miranda has a Canon forum and a Post Processing forum. There are folks there that use the Pro-300; they may have ideas if you post there.
