PIXMA iX6580 Vertical Stripes on prints
Mackey_01
I'm having a printing problem- brand new PIXMAiX6580, stripes in the last quarter of my prints on
Pro paper Premium Matte when printed from Lightroom, the printer heads are cleaned and aligned - as I said the printer is brand new I haven't printed 30 prints so farBildschirmfoto 2026-01-18 um 19.49.05.pngBildschirmfoto 2026-01-18 um 19.49.05.png
3 REPLIES 3
Mackey_01
I just found out it's call "Banding" - is it a setting problem? some people say "only print from LR" but I read to get rid of this you need to print from the printer. If so what are the printer settings for Canon Pro Premium Matte paper?
DerrickL
Recommended Photo Paper Settings for PIXMA iX6580
Photo Paper Pro Premium Matte use Canon Matte paper MP-101 setting.
To achieve the best print quality on your PIXMA iX6580, it's essential to select the correct settings for the type of photo paper you are using. Below are the recommended settings based on different types of photo paper.
Media Type Settings
Paper Type Printer Driver Setting
Photo Paper Pro Platinum Photo Paper Pro Platinum < PT-101 >
Photo Paper Plus Glossy II Photo Paper Plus Glossy II < PP-201 >
Photo Paper Pro Luster Photo Paper Pro Luster < LU-101 >
Photo Paper Plus Semi-gloss Photo Paper Plus Semi-gloss < SG-201 >
Glossy Photo Paper Glossy Photo Paper < GP-501 / GP-601 >
Matte Photo Paper Matte Photo Paper < MP-101 >
Additional Settings
  • Prevent Paper Abrasion: Enable this option in the maintenance section of the printer driver to avoid issues like water spots on glossy paper.
  • Print Quality: Set the print quality to "High" for the best results, especially when printing photos.
  • Paper Size: Ensure the paper size matches the actual size of the photo paper being used to prevent cropping or misalignment.
General Tips
  • Always use genuine Canon photo paper for optimal results.
  • Make sure to load the paper correctly in the printer to avoid jams.
  • Adjust the color settings if necessary to match your desired output.
DerrickL
