Pixma Pro 10 - can't find on network
weimfamily
I had my Pixma Pro 10 set up for wireless printing from my Mac. Over the course of some eero updates, I can no longer see it on the network. It powers on, I can get the wifi into pairing mode. I have tried hooking it up to my eero via ethernet. I've tried connecting to my laptop via USB. No luck... any suggestions?
4 REPLIES 4
jrhoffman75
I suggest you remove the printer in System Preferences->Printers & Scanners. Then plug in USB and turn on printer. Select the "+" add icon and wait for the Canon IJ Series version of the printer to appear.
I don't know anything about mesh Wi-Fi but I have seen postings where the printer Wi-Fi doesn't play well with eero.
Thanks. I did remove it and when I hit the "+" it still doesn't find it. But I will try again (can't hurt). Thanks for the reply.
jrhoffman75
Try downloading and reinstalling the Canon driver. That frequently straightens things out.
sabuck0
I have the same issue. I changed out my Spectrum/Asus home wired and wifi network with Eero 6+ mesh network. I can plug my Canon Pro-10 onto the network via a ethernet switch and "see" it on the Eero home network with it's assigned ip (you must enable the lan function on the Pro-10). If I disable the lan function and make it a wireless connection, it connects, but the Eero does not list it as a connected device. Weird. I would appreciate any thoughts on this.
Friends and Family
