PP&L How to copy layout and other settings to another computer?
tpayne10
My laptop died that I use to print from Professional Print & Layout.
I can access the hold hard drive as a USB drive and am trying to figure out where to find all my customized settings so I can move them to the new laptop.
Help is greatly appreciated!
Tim
jrhoffman75
Tim
I downloaded and installed PP&L before I realized it won't work with my printer.
You could look here (need to show hidden folders):
A similar path works for me with PSP.
5 REPLIES 5
rs-eos
Are you using a Mac or Windows PC?  For a Mac, always best to use Migration Assistant which should preserve all settings from one computer to the next.
Ricky
Camera: EOS 5D IV, EF 50mm f/1.2L, EF 135mm f/2L
tpayne10
old laptop was Win10, new laptop is Win11
What is Migration Assistant and will it work for my particular issue?
That's only if you have a Mac, which you don't.  Migration Assistant is a special application Apple created to make moving from one Mac to the next a seamless process.   I'm not familiar if there's any equivalent for Windows PCs.
Ricky
jrhoffman75
Tim
tpayne10
I did copy the folder you referenced. However, after going back into the app, I had to do a little setup to be able to see layouts. I had to change the Layout Mode from Single Image to Multiple Images. Thanks!
Avatar
