PIXMA TS6320, Installing IJ Network Scanner Selector EX2
cwilliams1020
When I tried to open my IJ Scan Utility on my PIXMA  TS6320, I got the message that the Network Scanner EX2 could not be found, along with error 3,208,0. I know that both EX2 and the IJ scanner are installed on my computer, but when I open EX2, it recognizes no scanner at all. I've followed every troubleshooting guide and instruction in Support and cannot manage to reinstall EX2. I downloaded the MP drivers (I think...tried to, anyway). I've been using this IJ scanner on this printer connected to this computer for years. Now this. I hope someone can help. Thanks.
4 REPLIES 4
Tiffany
Moderator
Moderator
Hi cwilliams1020!
So that the Community can help you better, we will need to know which operating system is running on your computer (i.e. Windows or macOS and which version). How are you connecting? Error messages? Any other details you'd like to give will only help the Community better understand your issue. The forum is not intended for immediate support. If this is a time-sensitive matter, click HERE search our knowledge base or find additional support options HERE
Thank you!
Thank you, Tiffany. My OS is Windows 10, my browser is Google Chrome and the only error message is as described in my post above. Since posting, however, I went into my settings and uninstalled EX2. I read somewhere that I should reinstall it.  So now, I am trying to figure out how to do that.
Having the same problem trying to reinstall Scanner driver for a PIXMA TS6320 on a new HP computer.  Tried downloading every version of Windows - 11, 10, 10 X64, 8 - and still cannot get it to work.  Does Canon have a fix for this?
Hi Marminio77,
I'm not sure what you mean by that you have tried downloading every version of Windows.
Are you experiencing an error when attempting to scan?
Have you tried scanning by using the IJ Scan Utility?
If so, what is the exact error that you are getting?  What code appears at the bottom?
Are you using your PIXMA TS6320 wirelessly?  Or are you using it with a USB cable?
