03-07-2025
11:28 PM
08:36 AM
James_C
Windows 11 PC. The Printer is connected via WiFi. The Computer and Printer are on the same WiFi network.
I Installed the software in this order. MF642CMFDriverV6405W64, then winmfscanutilityv12102, and finally MF740_MF640_Send_V102
In the Canon MF Network Scanner Selector, I can see the printer listed. I am able to print from my PC to the printer wirelessly.
When I try to initiative a scan from my PC, I get the following error:
ScanGear MF
Cannot communicate with the scanner.
The cable may be disconnected, or the scanner may be turned off.
Check the scanner status and try again.
Scanner driver will be terminated.
OK
When I try to do a scan to computer from the Printer itself, I can see my computer listed. But when I start scanning, the computer pops up the same error.
If I use the built in Windows Fax and Scan software, I am able to scan from the printer.
I'd like to use the Canon MF Scan Utility. Can someone help me fix this error?
Cheers!
03-11-2025 04:31 PM
Anyone else facing this?
03-11-2025 05:36 PM
Finally got a hold of Canon support and they mentioned Windows 11 24H2 boinks this.
One workaround that they tried and worked for me (and supposedly ~80% of folks) is to install this registry change which fixes it.
https://downloads.canon.com/cpr/software/scanners/RepairReg.exe
