03-01-2023 11:20 AM
am beyond frustrated with this. I have MacBook Air Catalina OS 10.16.7. No matter how many times I try, I cannot get this printer to connect wirelessly. It will connect via a USB. Obviously, I need help
03-02-2023 03:20 PM
Hi lmiller,
To connect your PIXMA TS3522 to your Wi-Fi, please follow the steps in one of the links below:
How to Connect TS3520/TS3522 to Wi-Fi using an Android phone or tablet
How to Connect TS3520/TS3522 to Wi-Fi using an iPhone/iPad
Once your PIXMA TS3522 is connected to your Wi-Fi, you will be able to add it to your MacBook and be able to print and scan wirelessly.
03-02-2023 04:05 PM
still not working
02-28-2023 10:03 PM
I am beyond frustrated with this. I have MacBook Air Catalina OS 10.16.7. No matter how many times I try, I cannot get this printer to connect wirelessly. It will connect via a USB. How can something so simple be so difficult?
03-02-2023 03:17 PM - edited 03-02-2023 03:19 PM
Hi lmiller,
03-02-2023 04:04 PM
Didn't work. I can actually see it on the network
10-30-2023 11:16 PM
So I've seen this on other wifi printers. It's usually a network that is a higher frequency than the printer's Wi-Fi antenna. I had to set up a 2.4 GHz band network for the printer. Once I linked it to that. Things worked like a breeze.
05-28-2024 11:43 PM
I have the same problem, over a year later. Like you, I did what Patrick suggested to no avail. And again. And again. Did you ever get your issues resolved?
