06-30-2021 06:45 PM
I just unboxed a new Pixma G620 mega-tank printer. Supposedly this printer is a WifI ready printer, but it only supports 2.4Ghz B & G, not even N
How do I connect this thing to my state the art Wifi6 only network? (802.11a/h/j/ac/ax)
All my devices are 5Ghz enabled or are connected via wired ethernet. Even the old MG7520 had ethernet & usb.
07-01-2021 10:38 AM - edited 07-01-2021 11:23 AM
It does support 2.4Ghz b/g/n
It does not support RADIUS or LDAP based authentication.
List of interfaces:
Hi-Speed USB
Wireless PictBridge
Wi-Fi® (802.11b/g/n wireless networking, 2.4 GHz)
List of interfaces:
Hi-Speed USB
Wireless PictBridge
07-01-2021 06:42 PM
I returned the printer to the place of purchase. On the back of the printer there was a mold marking for a USB port to be installed near the power plug, but it was not punched out nor was there a USB connector. It appears that this model no longer has a USB connection. The replacement unit that was brought out to me had a add-on label attached to the box showing new specifications. The label had a different model number PIXMA G620(v1.2). The new specifications did not include high-speed USB, and it specifically stated "wireless direct printing" without out mentioning 'WiFi' anywhere. So this model seems to only supports AD-HOC connections. My box did not have the add-on label. The display model also did not have a USB port, nor were we able to connect the printer to any wifi network. The only connections options in the menu were 'Access point mode settings.'
Maybe that is why this model has a retail price of $129.99 instead of the $299.99MSRP on the canon website.
I purhased a different printer with ethernet connection. Unforunately I'm stuck with fax and a dismal excuse Canon referes to as a scanner. The printer can do 600dpi, but the scanner is only 150dpi optical? Really? Most old, outdated standalone fax machines do 300dpi at least. But I digress.
