03-04-2019 06:20 PM
I've been using my MX340 for some time, and love it. Recently changed internet providers from AT&T to Fidelity, so I have a new modem. In the past I've had several different AT&T modems, and each time I'd let the MX340 detect the network name, and when I select it I'd get prompted for the passphrase. After entering it, everything immediately worked well.
When I select the new modem name, however, the MX340 immediately tries to connect, and of course fails since the passphrase hasn't been entered. I can see several other networks from my neighbors, and if I select any of them for a test, the MX340 immediately prompts for a passphrase. For my new one, it bypasses that step and tried to connect immediately. Any help on this would be sincerely appreciated - I've tried everything that I could think of, and can't find this problem online.
Thank you very much!
03-05-2019 12:15 AM - edited 03-05-2019 12:20 AM
If you run the software installer again, it gives you the option to select the wireless network and enter the network password again. See the guide below.
03-07-2019 01:10 PM - last edited on 03-07-2019 01:14 PM by Porcha
Hi mitchelwhit,
When you run the installer, make sure you have the printer usb cord that came with the printer connected. Once you enter the wireless information and the printer is connected, you can remove the usb cord.
