Canon MF655cdw Scan Utility not working on Win11 24H2
michal2512
Hi. After update to Win11 24H2 Scan Utility stop worked.
I have second instance of Win11 23H2 on the same PC and there is everything OK.
I was trying reinstal all drivers and utility - without result. I was disabled firewall and virus protection - without result.
Printer is connected via LAN.
Microsoft app from Store - Scan - is working excelent , Scan Utility from Canon not. Any suggestions?
19 REPLIES 19
michal2512
I did it :).
Clearly your diagnostics was very thorough.  👍
Last recommendation would be to implement a backup solution.  You could then revert to a point in time where the scanner worked.  It may or may not have yielded a different outcome the next time 24H2 was applied.  Sometimes, however, reinstalling is the only way to resolve.
~R5 C (1.1.2.1), ~RF Trinity, ~RF 100 Macro, ~RF 100~400, ~RF 100~500, ~RF 200-800 +RF 1.4x TC, BG-R10, 430EX III-RT ~DxO PhotoLab Elite ~DaVinci Resolve Studio ~ImageClass MF644Cdw MF656Cdw ~Pixel 10 ~CarePaks Are Worth It
Did you solve the problem?
normadel
Since you reinstalled Windows, you do not HAVE to do the 24H2 update if it is causing the issue. Microsoft can go way overboard on what their version updates do and they are not foolproof.  If you don't care about what they say it does, don't do it. Don't let it happen automatically. My 23H2 computers are perfectly fine.
After OS reinstall, this and his other system are working with 24H2.
audrius
Hello, what is the problem? I have two computers with 24h2 fully updated and scanning is not possible. with version 23h2 everything works fine. What is the solution? roll back to an older version?
michal2512
Hi again. I don't know what caused the problem in one of my Windows instances. It was a fairly new installation. I used it for maybe 2 weeks. I didn't check if the scanner worked after installing the drivers because if the printer worked, I figured the rest should work too. The need to use the scanner caused me to start the scanning program. And then I noticed that the Scan Utility for Canon program didn't see the scanner, although other programs, e.g. Microsoft Scan, worked correctly. Reinstalling the drivers, disabling AV, scanning the system, etc. didn't help. I gave up and reinstalled the system. And so far everything works correctly. After each installation of a new application, I check if something has broken and if I come across something, I'll write in this thread. This is not a good solution, but the only one that worked. I hope Google Translator translated it fairly correctly. Best regards
Luvbird
I have the same problem. After spending hours on the phone with Microsoft and Canon, it was determined that the issue is that Canon needs to fix the driver. I am waiting for Canon to either issue a patch or a new version of the driver.
zachster
Still same situation- Canon support acknowledged the issue a month ago, I've been checking the driver list nearly daily and still no updates. Brand new computer- Core 7 Ultra 265 on a brand new write from literally the week everything launched- not gonna rewrite my machine for one driver- yeesh. "Get it together rabbit troop."
