10-25-2024 02:53 PM - edited 10-25-2024 02:54 PM
Hi. After update to Win11 24H2 Scan Utility stop worked.
I have second instance of Win11 23H2 on the same PC and there is everything OK.
I was trying reinstal all drivers and utility - without result. I was disabled firewall and virus protection - without result.
Printer is connected via LAN.
Microsoft app from Store - Scan - is working excelent , Scan Utility from Canon not. Any suggestions?
10-26-2024 09:44 AM
Thanks for the update. I suspected this might be the case. If not already done, I'd uninstall the printer. Remove the drivers, restart and reinstall. Hopefully this will solve the problem for you.
10-25-2024 03:29 PM
What version of the MF Scan Utility do you have installed? Hopefully 1.21.0.2?
Let me go check what feature release I have on a W11 box.. 23H2 or 24H2...
10-25-2024 03:34 PM - edited 10-25-2024 03:37 PM
Stil have 23H2 on my box.... I'll test 24H2 this weekend.
Grab v1.21.0.2 if that's not the one you have.
10-25-2024 03:50 PM
I have Scan Utility v1.21.0.2 on both Windows.
10-25-2024 03:59 PM
Are you running 3rd party AV by chance?
10-25-2024 04:38 PM - edited 10-26-2024 12:40 AM
I'm using Eset Internet Security but for the testing I was uninstaled them. After that I was turned off Defender Firewall. And still not working. Maybe I had to reinstal drivers once again yet but I don't think that it help.
10-26-2024 07:19 AM
Hi again. I had some time and I've updated my another computer to 24h2 and there are no problem with scanning. So, this is another reason.
10-26-2024 09:44 AM
10-26-2024 11:58 AM
shadowsports wrote: "...Remove the drivers, restart and reinstall..."
I did it many times, in different ways, but without success. I don't know what could have caused it, but I ended up reinstalling Windows. Then I installed the Canon drivers and so far everything works. I install my software one by one and always check the scanner's operation. I'll see if any of my programs are causing a conflict. Thank you for all your suggestions and interest in the problem (Google translator)
10-26-2024 12:42 PM - edited 10-26-2024 12:42 PM
Greetings ,
Thanks for your reply. Running system file checker might have been another thing you could have tried before reinstalling Windows. This is performed from an elevated command prompt. The command is >SFC /SCANNOW
This is a windows system file integrity checker. If you Google the command you can read more about it. Glad you solved it.
