Point & Shoot Digital Cameras
Power shot SX740 HS
I'm wondering how I could connect My camera to another wifi camera. My friend has this camera and she has the option to connect to another camera. instead, I only have options to connect to a phone, a printer or a website. what can I do to be able to...
PowerShot SD700is memory card failure to load
Hi,I have an old PowerShot SD 700is and just bought a 64Gig card for it. The card works fine in my PC but the camera keeps reporting that there is a memory card error and the Format function is greyed out. I have tried formatting it via my PC using a...
hrensin by • Apprentice
  • 4982 Views
  • 9 replies
SX280HS E32 error (not video)
Had this camera for close to a year now. Did the firmware update a long time ago.Lately, the camera just shuts off on its own with an E32 error. This happens after turning it on and taking 2, maybe 3 pictures. I tried to update the firmware again and...
dakumar by • Apprentice
  • 38434 Views
  • 10 replies
Resolved! Canon Powershot S110 Soft Focus
When I use the camera (rarely), no matter what mode I'm trying, I get the "keep camera steady" icon in the lower left corner of the LCD. Sometimes, if lens is at widest point, I don't see it. However, in all situations other than that, it's there and...
Resolved! Powershot G5X Stops Videoing
I purchased a used Powershot G5X a couple of years ago, and I've found that it shuts off while videoing. At about 16:00, the timer turns red and the camera stops videoing. When the timer turns red, I've tried tapping the shutter release button and pr...
dark shadowy spot on photos SX530 HS
https://imgur.com/92NWossWhat is causing the shadowy dark spot at the bottom center of above-linked photo?.  It's on all photos taken recently.  This is an uploaded file from the camera. It shows on the live screen, too. It only goes away when i max ...
Lens repair
My Canon Powershot Elph 180 suffered it's second lense system damage; I accidentally ran over it while mountain biking and it's sections of the lense are pushed in at weird angles, you can hear something shaking inside and it forgot what time it is.W...
ng3689 by • Apprentice
  • 8951 Views
  • 9 replies
Resolved! Firmware Updating Issue
Hello,I own a Powershot SX740HS point and shoot.  The camera has an issue in which I get an Err 60 and a once in awhile white bar on the bottom of the screen.  From what I can tell, this appears to be firmware related.  Now here is the fin part.When ...
Fordman by • Apprentice
  • 2289 Views
  • 2 replies
Powershot sx30 is
I bought 7” field monitor to use with my powershot SX30 IS I’m having difficulty getting the monitor to work right? I can see playback video and pics that are already saved to the sd card but it won’t work live on the monitor so I can take pics and v...
Resolved! Wirelessy upload images to PC
PowerShot 720 HSWhen I bought this camera, I had a Windows 10 PC and successfully wirelessly uploaded images from the camera to the PC. However, I now have a Windows 11 and am not able to connect from the camera to the PC nor using Add A Device to se...
