12-02-2017 07:49 PM
Ok, so I'm getting really grumpy here & it appears that quite a few others are having the same issue. Up until a couple of weeks ago, I could download my photos from my camera onto my computer but now, not only can I not download my photos, my computer won't even recognize my camera!! I am using exactly the same cord that I have always used, I have even tried new cords but to no avail! It is extremely frustrating and quite frankly, annoying! Any suggestions as to why this may be happening? Thanks.
12-02-2017 08:10 PM
Hi, fimason!
To have a better understanding of your issue, please let everyone know the version of Windows or Mac in use.
If this is a time-sensitive matter, our US-based technical support team is standing by, ready to help via Email at http://Canon.us/SupportCF
Thanks!
12-02-2017 08:18 PM
12-03-2017 10:09 AM
12-03-2017 08:00 PM
12-04-2017 03:21 AM
@fimason wrote:
I have always connected my camera to my PC to download my photos. I ended up taking the card out of my camera & downloaded the photos onto my laptop using the card slot on that. Frustrating!
Well, maybe just maybe, that which I've guarded against has happened to you now. If this is true then not good. As to being frustrating, it's a matter of weighing-up the potential damage against easy of use.
I have a LEXMAR Card reader, reading both SD and CF Cards ( output from my trusty XF300 camcorder) permanently USB3 to my PC, and another nifty lil card reader for my iPad AIR2 taking output directly from my SD cards content from my SX50HS. Nope, no frustration here.
I have an innate fear/objection to connecting devices that have differing voltages and amp draws to each other. It's a DNA thing!
12-06-2017 04:34 PM
Hi Fimason,
Thanks for posting.
When connecting your camera to your computer, we recommend the following:
When your camera is connected, as described above, please turn it on in the playback mode..
With your camera connected, as suggested above, and powered on in the playback mode, if your computer still doesn't recognize your camera, I recommend taking a look in your computer's Device Manager.
To access the Device Manager in Windows 8, press and hold the "Windows/ Start" key on your keyboard, then press the "X" key. You should see a menu appear. Click on "Device Manager".
Once in the Device Manger, please look for the Portable Devices folder. If your camera is in there, please right-click on the driver and uninstall the driver. Once this process is complete, please turn your camera off for a few seconds, then turn it back on (in the playback mode).
If you're still unable to transfer images after removing and re-installing the driver, please make a note of the contents of the following folders (if they're present):
Finally (and importantly), with the camera connected to your computer and turned on in the playback mode, what do you see on its display?
10-18-2020 11:31 AM
