Point & Shoot Digital Cameras
Canon G5X underwater photography
Canon G5X, Ikelite Housing, 161 Strobe connected.  Setting M, ISO set to 200 generally but will change as needed, Display Control set to M. the screen is too dark to be using as a viewfinder on M, if I set to AV the viewfinder is OK enough. how do I ...
Zop1 by • Apprentice
  • 2276 Views
  • 2 replies
PowerShot SX20is broken battery door
I've had a PowerShot SX20is for several years now and absolutely love this camera. It's perfect for my needs. My only issue with it is the battery door is broken and won't latch tightly. I have it taped with Gorilla Tape but that's not an ideal solut...
hbelkins by • Apprentice
  • 3505 Views
  • 2 replies
Canon PowerShot G12 dark screen mystery
After years of flawless operation my G12's LCD screen suddenly will not display but remains black EXCEPT in Video mode, C2 mode, & when looking at various photos on the memory card.  And..if I take a pic with the black screen in Auto mode I will hear...
Canon PowerShot S120 won’t power on.
My s120 seems to have given up. I made sure the original NB-6L battery was fully charged and the sd card is inserted, nothing. I have tried replacing the batteries but that won’t work. I even tried cleaning the pins with isopropyl alcohol and that di...
sirbxnny by • Apprentice
  • 2542 Views
Resolved! Powershot G7XII wifi connection Windows10
I cannot connect to my Win10 PC via WiFi. Have installed all the software and run the WiFi setup on the PC. Then I press the Powershot's WiFi button and:It finds the access point (my local home network)I give it the passwordIt finds my PD as a device...
Dvdtaylor by • Contributor
  • 71066 Views
  • 27 replies
LAMP, Powershot SX530HS
On the top of the camera, oposite side from the handgrip, on the top facing forward is a pencil-size clear window which the manual says is a "LAMP".  Cannot find any info on it in the users manual.  What is it and how and when is it used?
Thoughts On Canon G1X Viewfinder
I am thinking on buying a used Canon G1X (Mark 1, 2012 version) for casual shooting, because it is more portable than my 90D and has a large 1.5 sensor. I am worried because the optical tunnel viewfinder does not have good reviews. I always prefer to...
Chris_N by • Enthusiast
  • 2435 Views
  • 0 replies
Resolved! Cannot upload new photos from SX70 SD Card
I have an SX70 HS camera that I have happily used for several years.  Just now, I cannot upload some pictures I took yesterday, even though they are visible on my camera's display.  I have tried both Camera Connect to see pictures from iPhone and put...
HM-SX70 by • Apprentice
  • 2421 Views
Wi-Fi problem Canon Powershot SX540 HS
My Canon Powershot SX540 HS camera has always reliably connected with my iPhone Wi-Fi so that I can transfer photos to my phone for editing, sharing, etc., even in remote locations throughout outback Australia.But now when I try to connect my camera ...
jangil by • Apprentice
  • 2051 Views
  • 2 replies
Resolved! Windows 10 can't see G16 on wifi
I have a new computer with Windows 10. My Powershot G16 worked fine with Win 7 and my portable devices, but I can't get it to connect to Win 10. I installed Camera Window, I ran the wifi connection setup utility, which opened up some ports or service...
Resolved! Replacement flashbulb Canon SD450
Dear Friends,Hope all is well with all you fine folks.Is there a replacement bulb available for the CANON PowerShot SD450?How can one be certain it is in fact the bulb that's "bad?" and not any settings or something else?Any help or suggestions appre...
tapeinos by • Apprentice
  • 2278 Views
  • 3 replies
