Point & Shoot Digital Cameras
PowerShot A3100 Static Screen
It's been years since we last used this camera, and I'm really confused about this static screen. The battery is new, but I haven't brought sd card yet, cause I still want to look if it's not broken. (Surprise, it's broken) I saw other photos of a310...
Resolved! PowerShot SX20 IS Problem with memory cards
I have some new memory cards that aren’t working and whenever I put them in it keeps saying at the top of the screen memory card error with my power shot SX 20 IS I know that some memory cards work because I have some old ones that work and I can see...
Resolved! Powershot a540 lens won’t open/ No error message
Hello! When I turn on my powershot, the lens will not open. It makes no sound, which leads me to believe that the gears are not even turning. I put new batteries in the camera, the lens still will not work. The lens doesn’t appear to have anything st...
ka245 by Apprentice
  • 3527 Views
  • 2 replies
Powershot SX620 HS dirt inside lens
I have a Powershot SX620 HS that now has a speck of dirt inside the lens. I have no idea how it go in there or how to get it out. It is appearing in all pictures. Any advice on how to clean the inside of the lens would be appreciated
Powershot ELPH 110HS Flash Error
Hello! I have a Canon Powershot ELPH 110HS and the flash doesn’t work all the time even when it is set to “flash always on”. Is this an error with the battery or the flash bulb? It works occasionally, so I don’t think it is a burnt out bulb. Any advi...
SX720 HS - How to display date stamp on images
Hello, I am experiencing a similar issue with my SX720HS. I am unable to see the soultion posted earlier. If you are able to assist me with getting the date stamp setting (which does not appear in the settings of the camera) to be enabled I would gre...
czp263 by Apprentice
  • 3387 Views
Resolved! Clean HDMI out G7X mark III
I see there are a couple posts about clean HDMI out, but none that has the same issues I have, as far as I can see.Canon G7X mark III purchased last year. Firmware version 1.3.2.In the Advanced User Guide page 179 it says that the SHOOT5 menu should ...
kriftian by Apprentice
  • 5072 Views
  • 5 replies
Cannot upload photos from SD1000 to macOS 13.2.1
We had an older (12 year old plus) mac and have upgraded to a newer model that has macOS 13.2.1 with an M1 chip. Unfortunately the mac will not load the SD1000 software - apparently the software is for a 32 bit mac and our new mac is 64 bit. What do ...
parn by Apprentice
  • 3810 Views
  • 5 replies
Neck strap options for PowerShot S95?
I have a Power shot S95. It came with a wrist strap. I would like to attach a neck strap. I haven't figured out what will fit through the attachment slot on the camera.I could use the wrist strap attached to the camera and then add a neck loop. I tri...
keestone by Apprentice
  • 4760 Views
  • 5 replies
PowerShot SD500 Memory Card Error
My dad lended me the Canon Powershot SD500 and everytime I put my SD card in the camera it gets a memory card error. I’ve turned the camera off and on and even formatted the card and I still don’t know what to do please help
Wanexxx by Apprentice
  • 4844 Views
  • 3 replies
