01-05-2024 04:06 PM - last edited on 01-07-2024 07:55 PM by Kristoff
The camera's time settings are accurate for today, yet the files appear to be marked as created 24 hours ago. How can I fix this other than setting the camera's date and time settings 24 hours ahead? Thanks.
Using Ubuntu 23.10
01-08-2024 04:39 PM
Hello Prenonix,
The PowerShot ELPH 340 HS only provides a 24-hour clock. There is no AM/PM option. So beyond 12 noon (12 PM), you would need to set the clock at 13:00 for 1 PM, for example. This could definitely affect your date when you take photos depending upon the time of day they are taken. Let's verify that the camera is set properly based on that.
01-05-2024 04:07 PM
Thanks for joining the conversation, Prenonix!
So that the Community can help you better, we need to know exactly which operating system is running on your computer (i.e. Windows or macOS, and which version thereof) and which apps you're using to view your photos. That, and any other details you'd like to give will help the Community better understand your issue!
Thanks and have a great day!
01-05-2024 04:23 PM
Ubuntu 23.10. I'm just looking at the date stamps on the files, they open fine.
01-08-2024 04:39 PM
Hello Prenonix,
01-09-2024 06:31 AM
Are you reading the image file EXIF metadata, or are you reading the file’s creation date in the general properties?
If you captured images yesterday, but did not save them to your computer until today, then the saved files will have today’s date on them. The actual date of when the image was captured is embedded within the image file as EXIF metadata.
01-09-2024 06:22 PM
The images were taken on the same day there were viewed on the SD card by the computer; the files were not actually saved to the computer.
01-09-2024 09:08 PM
You should always copy ALL of the files to a computer. Do not rely on the memory card inside the camera for long term storage.
Again. How are you reading the dates? What app are you using?
If you copy the files to your computer, then what dates do you see? ARe you reading teh EXIF data or the file creation date?
01-14-2024 05:21 PM
Was the clock, I had set it to 12 hours in the past, apparently.
