PowerShot A4000 IS says Memory Card Locked
Tried the solution I found here regarding a switch on the battery. No such switch exists on mine. Help?
A recently purchased Elph 330 HS can get through about 20 photos, some with flash, followed by single wired upload, before the message "recharge the battery" appears. LIkely cause: is this a bad battery, a camera defect causing rapid drain, or a...
my A4000IS will not display more than two shooting modes when the up arrow button is pressed repeatedly per the instruction manual (page 68). it worked when i first purchased it about a year ago. anyone else have this issue? internal computer prob...
I need help! I have owned the SX210 IS for a couple years now. Recently I have discovered as I print my photos, the image is cropped, regardless of whether I print them in 4 x 6 format or 4 x 5.33. Before this problem occurred (starting around 6 m...
Im wondering if a Waterproof Housing will be available for the Elph 340HS.
Hi, I'm new here.Where can I download Canon Camera Window for iphone?. It isn't available in Argentina's Apple Store and I'm not allowed to download fron other apple stores. I bought a Powershot sx700 in USA but I'm not able to connect it to my iphon...
My computer says it can't find the camera when I try to download photos with ZoomBrowser (they only way I know of to download them). Solution?
It might just be a setting somewhere, but when I try to make a video the camera only takes a (one) photo. It still gives the remaining recording time etc.How to correct this?
Camera Problem--PowerShot G9--Both my apparently charged camera batteries are all of a sudden not turning my camera on. Maybe the on-off button is not making a connection in the battery compartment?Did something fall out, or did I overcharge both li...
Hello I realy dont like the idea of using Batteries On the other hand we have so much options in using Cell batteries , easy to replace with anykind of cell , You can purchase disposeable cell if you are travelling where we get little time to stay a...
I have a Powershot 590 camera & am looking at 40SX. Is this a step up or no?
Hi, We're on our honeymoon and been taking good pictures without any problems with Canon S110 until yesterday. The camera suddenly has the following problems:1. turn on normally but then immediately taking one photo no matter what mode it's on. 2. o...
why does it take longer for my A540 to process a photo than it did when it was new?
I did everything right, and got email conf.
Power button does not work
| Subject | Author | Posted |
| 08-21-2026 08:18 PM | ||
| 05-22-2026 11:35 AM | ||
| 04-23-2026 08:44 PM | ||
| 04-13-2026 11:03 AM | ||
| 04-08-2026 04:12 PM |
