10-19-2014 09:41 PM - edited 10-19-2014 09:44 PM
We have a Canon SX40Hs and cannot activate the digital zoom function. I have tried changing the mode from Auto to "P" to "Tv" etc and the dig zoom function is greyed out and not accessible. Any help?
Thanks
10-19-2014 10:01 PM
Have you checked Digital zoom is set to on?
Press Menu then move the control dial to highlight Digial Zoom then press the right or left side of the dial to select Standard which is the default setting..
10-19-2014 10:25 PM
Actually, this is a friend's camera, but yes, I went to the menu and when I got to the digital zoom option, it is greyed out (not accessible). That is the problem. I shoot in the EOS line so figured maybe there was a custom function somewhere that was causing the problem, but Power shot line apparentley doesn't have custom functions. Thought maybe digital zoom is only availabel in certain modes (pernaps not available in "green square"), but changing mode didn't seem to make it accessible either. I am just not familiar with the powershot cameras so ... any other suggestions?
10-20-2014 09:45 AM
Ok in addition the digital zoom can only be used with aspect ratios of either 16:9 or 4:3 and the pixel setting must be set to L or 4:3 in all other pixel settings.
If you have those set then as a last resort try a reset to defaults through the menu.
10-20-2014 11:40 AM
Camera was at 4:3 and L fine. The owner claims to have already done the "return to defaults" so I was and still am stumped.
