07-10-2023 03:37 AM - last edited on 07-11-2023 08:41 AM by Danny
I want to setup my R5 so that I can rapidly move from photo to video and back. With my R6 I simply activate video from photo mode by depressing the red video button. When I stop the video the camera returns to photo mode.
I have spent days trying to achieve the same sequence on my R5 without success. In video mode the R5 works fine, however when in photo mode depressing the video button comes up with completely different video settings.
I try setting up the video settings with C3 unsuccessfully. Obviously I am missing something. Any assistance would be much appreciated.
Note: I use my Fn button for a particular function in photo mode that I do not wish to change.
07-11-2023 02:36 AM - edited 07-11-2023 02:41 AM
I programmed my M-Fn but as you stated, you have it programmed for something else. The next fastest way to switch video is to press Mode then INFO. that will switch between video and photo modes. While in photo mode, pressing the record button should use C3 setting. I'm wondering if you registered the C3 settings.
07-11-2023 02:46 AM
I also had a wierd issue with my R5 mode and video record button, had to send it into canon for top board replacement
Canon R5 M-Fn and Movie Record button stops workin... - Canon Community
07-11-2023 03:01 AM
Hi Jaewoo, Thanks for your response which is a workable option. In the meanwhile I have come up with another option which you may be interested in:
1. Make all the required settings in video mode.
2. Save these settings in C3 while in video mode.
3. Return to photo mode. At any time press red record button - video recording starts. Press video record button again and the camera returns to your photo mode.
Seems a complex work around, but will work for me who takes photos of birds with the occasional short video.
07-11-2023 04:28 AM
I dunno if I would call it a work around -- that's how it's supposed to work. I made a review of the R5, and among other things, I describe how this works. It may help. See: https://moonblink.info/MudLake/gear#R5 @04:29
07-11-2023 04:19 PM
correct, my solution had 2 parts, 1) switching modes and 2) configuring C3 so you can use the video record button while in photo mode. we explained the same thing.
12-21-2023 12:11 PM
When you say switch to video mode -How?
I pressed mode then info and the in menu don't see video settings.
