09-13-2019
10:08 AM
08:51 AM
James_C
I LOVE THIS PRINTER; however I just started getting toner spots in MAGENTA color. I have now immediately changed the toner cartridge, but the spots continue. Can you please forward the proper steps for cleaning the items that I need to clean on my model as was done in another stream for a different Cannon model.
THANKS
Erik
09-13-2019 03:27 PM
Hi pgmerik.
It is recommended that you perform a fixing unit cleaning and transfer belt cleaning.
Note that you cannot clean the fixing assembly when the machine has documents waiting to be printed.
To clean the fixing assembly, you need plain A4 or Letter size paper. Set the paper in the paper drawer or multi-purpose tray before performing the following procedure.
Loading Paper in the Paper Drawer
Loading Paper in the Multi-Purpose Tray
- Cleaning consumes the toner cartridge. Make sure that there is sufficient toner cartridge remaining beforehand.
Checking the Amount Remaining in the Toner Cartridges
<Maintenance>.
Cleaning starts. When a message appears notifying that cleaning is complete, press
to return to the Home screen.
Transfer Belt
<Maintenance>.
Cleaning starts. When a message appears stating that cleaning is complete, press
to return to the Home screen.09-13-2019 03:27 PM
Hi pgmerik.
<Maintenance>.
Transfer Belt
<Maintenance>.
to return to the Home screen.09-15-2019 07:09 PM
New cartridge and these cleaning steps WORKED!!!
Thanks
Erik
03-02-2022 08:15 PM
I have tried this so many times and it says cannot cleaning fixing assemble or ITB why? I am following the directions
12-01-2022 03:07 PM
Same here. "could not perform cleaning"
01-13-2025 04:22 PM
I'm having the same problem on my MF632Cdw laser printer, but the magenta is big horizontal streaking of magenta bands. Anyone know what to do about that?
01-13-2025 04:27 PM
Those maintenance steps did not help clear up the magenta streaks/banding on my My MF632Cdw laser printer. Anyone know what to do about that?
04-22-2025 08:50 AM
For any streaks / banding it's recommended to change the toner cartridge. Hopefully your using real Canon toner. I believe if the cartridge is fairly new and causing issues Canon will give you credit (at least they should)
