07-12-2022 08:11 AM - last edited on 07-13-2022 08:51 AM by Danny
Hello. The fact is that I lost all the factory packaging and documents. My printer is mf 3010. The problem occurs when I try to connect the printer to the computer using USB.
07-12-2022 09:19 AM
WPS code is generally something related to your router.
Do you want to use your printer direct connected to USB (in which case Wi-Fi is irrelevant) or are you trying to set up your printer for Wi-Fi using the USB connection?
07-12-2022 09:52 AM
I want to print using a computer and USB, and when I want to add a printer in the settings, a window appears asking me to enter the wps code
