01-08-2020 01:26 PM
Color imageCLASS MF644Cdw keeps giving me yellow streaks only on print side. I've circled them in red on the image below....
I've tried:
1) removing and reinstall the toner cartridges;
2) "clean fixing assembly"; and
3) "clean ITB"
4) "reduce drum steak";
01-10-2020 02:14 PM
Hi FrankCurrah.
With consideration to the steps you've taken and the symptoms, this may be a problem with the yellow toner cartridge's drum. If the yellow toner is still within the thirty (30) day post-purchase warranty period, contact us using the numbers and information at http://Canon.us/ContactLI
If the toner is no longer under warranty, try replacing it with a fresh yellow toner cartridge (Toner 054 standard or High Capacity).
01-10-2020 02:14 PM
Hi FrankCurrah.
01-16-2020 07:09 AM - edited 01-16-2020 07:09 AM
There is no accept solution button? We're going to use out the yellow toner then replace...
Edit: and it appears after I replied...
07-11-2022 10:28 AM
I have the MF632 and I am having the same issue now. How did you fix it .
07-11-2022 10:38 AM
After replacing the yellow cartridge and cleaning up, the issue went away.
