12-16-2014
03:21 PM
02:15 PM
Hello,
First time Canon purchaser. Just got my new ImageClass LBP6230dw wireless laser printer. Connected to my Mac OSX with Mavericks operating system. Downloaded required software from Canon online. After installing everything, all printing works perfectly (recognized in print utility when USB is plugged in... however, when I unplug the USB port, the print utility shows printer now OFFLINE or sometimes it is not even recognized - therefore cannot print anything because it no longer shows.
I want to print wirelessly.
I have everything setup in regards to my wireless setup assistant - all network wifi-address is correct, WPA security is set, etc.
Also, the wifi blue light on the printer remains lit when I unplug the USB so that is okay. But cannot figure why unplugging the USB cable into the computer port is problematic.
Help appreciated.
04-28-2016 10:49 AM
The fix doesn't last. I'm back where I started. I tried to print wirelessly to my printer, which has remained turned on and got the familiar error message that the printer is not responding. I don't know what else to do.
04-28-2016 10:50 AM
I forgot to mention that I tried turning the printer off and on again. That didn't work either.
04-28-2016 12:44 PM
Yup, I hear ya. I finally gave up on trying to wake up the printer wirelessly. I had a 50 foot network cable laying around, and ran it between my printer and my wireless router. Wakeup problems solved.
Besides, the hard-wired network connection is about 10X faster than the wireless connection, anyway. In the end, I think I would much rather have the speed. You can buy a network cable that long for about the cost of a burger combo at your favorite fast food joint. Some places will charge you 3-10 times that amount for a CAT-6 cable.
04-28-2016 12:48 PM
I'm thinking of plugging my printer into the nearby Apple wireless repeater device to solve this problem and will report back if that works.
04-28-2016 02:22 PM - edited 05-06-2016 11:17 AM
I tried plugging into the local airport express node that connects to my wifi network and couldn't get anywhere. However,
I may have solved the issue! Not. See next post.
I called Canon support again, connected to another of their helpful U.S.-based representatives, Curtis. We tried to think it through and got me printing without reinstalling the printer on the network. He said that even shutting down a MacBook and starting up again the next day doesn't clear the cache. If you're working on more than one network, settings may be held from these different networks rather than re-set to the current one. He said that a restart clears the cache in a Mac. With him on the phone I restarted it, opened a document, told it to print. It took about 20 seconds for the printer to connect and start printing, but it did. This was without turning the printer off and on.
Here are some other things Curtis said that could help others in this situation. If the problem is not with the printer (awhile back Canon sent me a refurb unit to try in place of my new one. That had the same problem, so I returned that printer), it is probably with the MacBook (maybe 10%) or with the router (90%). Also several months ago I took the MacBook and the printer to an Apple store. I didn't take my router. I was working with an expert guy there who worked with me for 40 minutes before keeping the printer and MacBook overnight. I was able to get working but continued having the same issue discussed here, where the fix doesn't last.
Here's what Curtis suggests, in this sequence:
Restart the router at least 4 times a year, regardless of router manufacturer
Restart the printer
Restart the Mac
This will keep all devices smoothly interfacing and should also benefit the functionality of the Mac.
I will assume now that it's all working. If these fixes and procedures don't hold, I'll check back on this thread. For now, kudos to the fine people at Canon, Apple and this forum for helping me solve this problem.
05-06-2016 11:15 AM
I tried to print today wirelessly and the printer wasn't found. I rebooted my computer and it wasn't found. Not solved.
05-15-2016 11:41 AM
Just on a lark, I tried to print today and it worked effortlessly in wireless mode. Maybe I need to do more troubleshooting with the router.
05-15-2016 06:15 PM - edited 05-15-2016 06:17 PM
@drgary wrote:Just on a lark, I tried to print today and it worked effortlessly in wireless mode. Maybe I need to do more troubleshooting with the router.
Just on a lark, is it possible the router is switching frequencies to find a clear channel? I am certain that my issue is related to something in my router. Frequently, my laptop fails to connect wirelessly, and I have to log in again to my router. When I do, I wind up seemingly duplicate connections, which makes me suspect that the router has changed frequencies. Windows 7/10.
Also, I read a thread on this forum about how disabling IPv6 in some printers helps Canon wireless printers.
05-15-2016 06:26 PM
Hard to tell. I'll have to ask Apple since I'm using an Airport Extreme network or my ISP, which provides its own wireless router.
04-24-2017 12:14 PM
I am having an issue with mine as well. I have had issues since Day 1 but after realizing taking my macbook to and from work was messing with the network recognization, all I needed to do was turn the wifi off then on again when needing to print. Today the blue light is just blinking and no matter what I do it won't go solid or connect wirelessly.
Help!
