08-23-2025
06:00 PM
07:10 PM
Tiffany
I have a new MF273dw network printer. No matter what I try (Wired LAN, wireless LAN, USB) Nothing works. I can print from my phone and iPad when connected to my router. My windows 11 PC will not allow me to load the drivers until it sees the printer. When I try to use USB, I get an error does not recognize device. also tried to connect to printers IP address with computer but i get nothing.
08-23-2025 08:17 PM
Thanks for the input, I have fixed the problem. I checked my connections and found I had my computer connected to my T-mobile modem. I disconnected and connected PC to my router. Stupid error but all is well now.
08-23-2025 06:16 PM - edited 08-23-2025 06:25 PM
Is your PC a laptop or desktop? If it's a laptop is it ARM based?
Are you using a third party antivirus solution that might be blocking communication?
During the troubleshooting process I would ask that you pick one interface (connection method) and stick with it. I would recommend wireless since it's the most versatile and allows any device connecting to the same network to use the printer.
08-23-2025 08:17 PM
08-23-2025 10:33 PM
It happens. No worries. Glad it's solved 🙂
