Print Issues LBP7110Cw
marksmacy
Hello to all:
I am having printing issues with my LBP7110Cw when I try to print using Avery lablel stock.  It works well with standard paper, but when I use the Avery Labels, it seems to have streaking and the "Ink" rubs off very easy.  I have run the self cleaning optin many times and it doesn't help and now the standard paper printing seems to have blotches (where it doesn't print well) occuring.  so my questions does anybody know what the issue might be and a follow up question would it be econ0mical to take the printer to a repair shop or to just pourchase a new printeer?
THank you for any and all answers
Mark
1 REPLY 1
Sonya1
Hello marksmacy,
I understand you are having printing issue with your Color imageCLASS LBP7110Cw.  The LBP7110Cw is designed to print labels (only) from the multi-purpose tray. After loading the labels in the multi-purpose tray, you will need to select "Labels" for the Paper Type in the printer driver on your computer prior to printing.
Based on the information you have provided, it sounds like one (or more) of the labels might have damaged the drum inside one (or more) of the toner cartridges.  What color are the blotches when you perform standard printing?  Did the Avery label stock say it could be used specifically with "laser printers"?
If you need immediate assistance and you're in the USA, please click http://Canon.us/ContactCF for our US-based support. If you're outside of the US, please click http://Canon.us/4xf7 for support options.
