Preventing printer sleep / WiFi disconnection - imageCLASS LBP632Cdw
chad9
I have a Color imageCLASS LBP632Cdw laser printer connected to my WiFi. It goes into sleep mode and is no longer found on network for printing, I have to go to printer and physically wake it before being able to print
I cannot find a setting to disable sleep mode completely, how can I solve this annoying problem and have the printer wake upon print commands, or just never go into power save/sleep mode?
Gave up and replaced it with a Laserjet. Toner may cost a bit more (not sure), but it solved this WiFi/sleep issue and the printer just works every time I hit print from a mobile or laptop.
4 REPLIES 4
ingallspw
Same issue here! This printer is about to be returned.
Hi! This community is designed for your fellow Canon owners to help each other out with any problems they may encounter. If this is a time-sensitive matter, click HERE search our knowledge base or register your Canon gear HERE to access additional support options.
Thanks and have a great day!
It is laser. And yes I am giving up.
Returning it as it sounds like anything Canon with Energy Star on it forces you to conform.
Friends and Family
