02-21-2019 11:40 PM
02-22-2019 08:58 PM
02-22-2019 12:15 AM
02-22-2019 06:29 PM
Hi MTBioGuy.
With the imageCLASS printers, you will need to set the paper settings on the printer to match the settings from the device you are using for printing.If you are using two different sizes of paper, then the correct tray should be detected automatically. However, if you are using the same size paper in both trays, you will need to set the paper source in the printer settings on the device.
For your Android device, using the Canon Print Business App, on the Preview screen you should see an option for [LTR], [1 Copies], and [Print Range: All]. Tap this area and it will bring up the printer settings. Next, tap Source or Paper Source. Select the multi-purpose (MP) tray there, and then return to the main print screen. Tap [Print] and the machine should start printing from the MP tray.
If you still continue to experience an issue, please call us at 1-800-OK-CANON (652-2666), Monday - Friday 10:00 a.m. to 6:30 p.m. ET (excluding holidays).
02-22-2019 08:58 PM
09-23-2019 04:08 AM
Can anyone tell me how where the new posting button is?
09-23-2019 10:06 AM - edited 09-23-2019 10:07 AM
Hi Seventhgalaxy,
Here's how to post a new message to one of our message boards:
1) Select what your product type is from the 6 options at the top of the screen (About the Community, Camera, Printer, Cinema EOS, Camcorder, or General Discussion).
2) On the next screen you'll choose more specifically what your product is (for example: personal printers, office printers, etc... from the printer list)
3) Finally, on the next screen towards the top left there will be a "New Message" option.
We hope this helps!
09-26-2019 11:24 AM
Honestly, the WORST idea was to make this purchase so to all those thinking about it DO NOT. Even my Manager is disappointed. The paper WILL NOT feed from the main tray and you will lose your mind trying to figure this out. Then you call into the help # and are on hold for so long you end up hanging up. DO NOT BUY THIS! I am aboutto ship it back because this is unbelievable when I was the one who talked up this printer. HORRIBLE EXPERIENCE. It has been sitting here for two montsh already!!!!!!
