10-26-2023
10:20 AM
10:28 AM
No issues printing however, can not scan and have it send to my email (PDF)
It scans and says sending but then prints a "TX Result Report" that just says ERROR
01-10-2024 03:21 PM
Hello BDW1,
It looks like the Ifax or fax option is starting if you are getting an error report after scanning. You can try reviewing the steps for scanning from the operation panel using the steps in the link HERE to make sure the settings are correct.
We would be happy to assist with the issue. To provide some feedback or some troubleshooting steps, we would need some additional information. If you could reply to this message with the information below, we can provide some assistance. For a more immediate resolution, you can contact support over the phone at 1-800-652-2666. Our agents would be happy to assist.
01-11-2024 10:40 AM
Hector,
I have reviewed your comments and can't get it to work. For clarity, I am not trying to scan to a computer; I am trying to scan to email. Again, I am scanning from the MF743 directly. I hit scan to email, choose the email from the list, hit apply, start the scan and everything seems fine. It say scanning on the display, it finishes with no issue but then immediately prints a " TX Result Report." that just says "Error" followed by my email address which is a correct email. I have tried several different emails addresses to make sure. I get the error report every time. Also, I will add that I can scan to an USB stick just fine. Just cannot get it to scan to email.
07-07-2024 09:08 PM
How did you resolve, I have the exact same problem.
07-07-2024 10:04 PM
Receiving a TX Result Report. This is a FAX specific report. It can be configured to print after each send operation or only when there is an error.
The same is true for E-Mail/I-Fax/File TX Result Report.
See the settings here:
Sending or receiving Fax, Email or documents to a folder or mail recipient requires additional configuration. Similar to how you configure a mail client on your computer, your mobile device or iPAD, etc.
Scan to Email requires an email provider. Example, Gmail, M365, Yahoo, Comcast, etc. Here is information about the printer configuration.
Please identify the mail provider you plan to use. At minimum you will need:
SMTP Server name (example Gmail) smtp.gmail.com
Username: typically, the email address of your account
Password: The password you use to log in
Sending Port: (varies by provider) 25, 465, 587
Encryption: normally SSL or TLS
Configuration is best performed in the printer's UI / web server.
Please see my reply in this thread. It has all the steps for Send to Email configuration. The interfaces between the printers is the same. This is for reference. Your settings will differ, but the fields are the same.
Re: ImageCLASS MF753cdw Remote UI Missing Network ... - Canon Community
