04-06-2023 09:43 PM
04-06-2023 11:58 PM
You'll need to supply the SMTP server address of the mail service you are using for relay.
The email address is the username or email address for the account you are using to authenticate.
Example M365
Device or Application setting Value
Server/smart host smtp.office365.com
Port Port 587 (recommended) or port 25
TLS/StartTLS Enabled
Username/email address and password Enter the sign-in credentials of the hosted mailbox being used
Hint, if you use Gmail, create an App Password.
04-08-2023 09:13 PM
That doesn't work. I've got an AOL e-mail address. So, I've got it set at:
SMTP Server: smtp.aol.com
E-Mail Address: [my e-mail address]
POP RX: Off
POP Authentication Before Sending:SMTP Authentication (SMTP AUTH):Use TLS for SMTP:Use TLS for POP:
| Off |
| Off |
| Off |
| Off |
And when I try to scan something and send it to my e-mail address, it prints off an error sheet:
TX Result Report
Job Number: 0001
Start Time: [the time the job was tried]
Sheets: 0
Error: [my e-mail address]
04-08-2023 10:52 PM - edited 04-08-2023 11:03 PM
I found this doing a quick Google Search. It appears AOL also requires that an app password be created. I don't have AOL so I have not verified this. Instruction should be available in your account.
04-10-2023 12:02 AM
I must be on the wrong screen then, because I don't see most of that. Here's what I've got:
04-10-2023 09:10 AM - edited 04-10-2023 09:11 AM
Thats correct. you're not. The printer has a complex feature set.
Please read this entire section, the instructions for changing the port at near the bottom. Note, the printer has to be restarted after the settings are completed.
See this as well for additional assistance:
Create and manage third-party app passwords - AOL Help
Looks like you are pretty close 😀
